Steering rod hitting front diff
11 years 6 months ago #143694 by Johnniehec
markyp2000 wrote:
Busta wrote: Castor angle and suspension changes won't affect the distance between the steering rod and diff. It's either bent (should be dead straight on rhd jimnys) or your kingpins are massively worn.
Yes it will if the bushes arnt fitted right or worn
Sorry I agree with Busta, worn or incorrectly fitted bushes won't make any difference to the distance between the track rod and the diff/prop. The track rod is connected to the hubs which are on the end of the axle tube so it's either bent or there's lots of play in the kingpins as Busta says.
11 years 6 months ago #143711 by Busta
If it was hitting the radius arms I'd agree, but it's not.
11 years 6 months ago - 11 years 6 months ago #143745 by kirkynut
Many people, including myself have run a 3" lift with no castor correction and no problems like this.
Something must be wrong or bent somewhere. Take the rod off and check it for straightness. They're not known to bend but I have heard of it. Accident damage may be the case.
It's tight to start with so worn components may take up the room between by allowing movement towards it but I'd have thought you'd have death wobble so bad it renders it un drivable.
So my money is on a bent steering arm.
Last edit: 11 years 6 months ago by kirkynut.
Time to create page: 0.110 seconds
