Steering rod hitting front diff
- Jackshepherd94
03 May 2015 15:32 #143624
by Jackshepherd94
Steering rod hitting front diff was created by Jackshepherd94
Hi all, new to this site. The steering rod on my jimny is hitting of the front diff and the prop shaft bolts. It doesn't do it all the time, jus when I turn left and brake hard. What would I need to do to stop this happening ? Thanks
- markyp2000
03 May 2015 16:12 - 03 May 2015 16:17 #143629
by markyp2000
Replied by markyp2000 on topic Steering rod hitting front diff
Has the suspension been modded has it got carster corection bushes or arms is the arm bent. The trailing arm bushes may be worn or the bolt holes are elongated or king pins on one side
Last edit: 03 May 2015 16:17 by markyp2000.
- Jackshepherd94
03 May 2015 17:00 #143633
by Jackshepherd94
Replied by Jackshepherd94 on topic Steering rod hitting front diff
Yeh it's got a 3" suspension on it, I don't think it has the castor bushes in. Jus had a look at the arms then and they don't look bent. One of the bolts going through the front right bushe was loose so I tightened it but my jimny isn't running jus now
03 May 2015 23:10 #143641
by Busta
Replied by Busta on topic Steering rod hitting front diff
Castor angle and suspension changes won't affect the distance between the steering rod and diff. It's either bent (should be dead straight on rhd jimnys) or your kingpins are massively worn.
04 May 2015 15:27 #143664
by safari
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic Steering rod hitting front diff
is it a standard or custom made the steering rod and also chq bushes of the armsfor acsessive play
- markyp2000
04 May 2015 19:04 #143676
by markyp2000
Yes it will if the bushes arnt fitted right or worn
Busta wrote: Castor angle and suspension changes won't affect the distance between the steering rod and diff. It's either bent (should be dead straight on rhd jimnys) or your kingpins are massively worn.
Time to create page: 0.087 seconds
