Steering rod hitting front diff
  • Jackshepherd94
11 years 6 months ago #143624 by Jackshepherd94
Steering rod hitting front diff was created by Jackshepherd94
Hi all, new to this site. The steering rod on my jimny is hitting of the front diff and the prop shaft bolts. It doesn't do it all the time, jus when I turn left and brake hard. What would I need to do to stop this happening ? Thanks :)
  • markyp2000
11 years 6 months ago - 11 years 6 months ago #143629 by markyp2000
Replied by markyp2000 on topic Steering rod hitting front diff
Has the suspension been modded has it got carster corection bushes or arms is the arm bent. The trailing arm bushes may be worn or the bolt holes are elongated or king pins on one side
Last edit: 11 years 6 months ago by markyp2000.
  • Jackshepherd94
11 years 6 months ago #143633 by Jackshepherd94
Replied by Jackshepherd94 on topic Steering rod hitting front diff
Yeh it's got a 3" suspension on it, I don't think it has the castor bushes in. Jus had a look at the arms then and they don't look bent. One of the bolts going through the front right bushe was loose so I tightened it but my jimny isn't running jus now :(
11 years 6 months ago #143641 by Busta
Castor angle and suspension changes won't affect the distance between the steering rod and diff. It's either bent (should be dead straight on rhd jimnys) or your kingpins are massively worn.
11 years 6 months ago #143664 by safari
is it a standard or custom made the steering rod and also chq bushes of the armsfor acsessive play
if u worry u die if u dont worry u still die so why worry
  • markyp2000
11 years 6 months ago #143676 by markyp2000
Busta wrote: Castor angle and suspension changes won't affect the distance between the steering rod and diff. It's either bent (should be dead straight on rhd jimnys) or your kingpins are massively worn.
Yes it will if the bushes arnt fitted right or worn
Time to create page: 0.106 seconds
