Older g16b conversion help
- Markrush33
08 Feb 2015 20:35 #137309
by Markrush33
Replied by Markrush33 on topic Older g16b conversion help
Ok cheers ill have to do a bit more home work i think
- BENNY
08 Feb 2015 21:11 - 08 Feb 2015 22:28 #137311
by BENNY
Replied by BENNY on topic Older g16b conversion help
Hi mate ebay item 251714888972 engine. Item 351300249907 adapter plate. Use your jimny inlet and outlet manifolds
Last edit: 08 Feb 2015 22:28 by BENNY.
- Markrush33
08 Feb 2015 21:38 #137314
by Markrush33
The first item number doesnt work, ill get an adapter plate and engine mount from waterbabie 4x4 but im worried about the cam sensor now
Cheers
Cheers
- suzukisam
09 Feb 2015 06:11 #137325
by suzukisam
Replied by suzukisam on topic Older g16b conversion help
i wouldnt worry about cam sensor to be honest by the looks of your profile pic you have soft top like me so if you bought baleno engine you would still have to swap cam pick up ring or camshaft , once you get both engines out and next to each other its self explanatry really , but you would need some bigger injectors green baleno ones or possibly vitara ones ? not sure, i used the green baleno ones
- suzukisam
09 Feb 2015 06:20 #137326
by suzukisam
Ebay item numbers
351301116040
251818463869
151581175866
Vit engines theres loads of g 16 b eengins on at present
351301116040
251818463869
151581175866
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
09 Feb 2015 15:50 - 09 Feb 2015 15:52 #137385
by funkyjimny
Replied by funkyjimny on topic Older g16b conversion help
Baleno 1.8? thought these were only from abroad?
one on the bay now... 181657672605
Gary
Gary
Last edit: 09 Feb 2015 15:52 by funkyjimny.
Time to create page: 0.111 seconds
