Older g16b conversion help
  • Markrush33
11 years 9 months ago #137283 by Markrush33
Older g16b conversion help was created by Markrush33
Hi people, ive had a good look through the search tool but all the g16b engines used seem to be out of 2000 onwards grand vitaras. My question is ive got a complete '95 automatic vitara with a g16b engine that i want to put in my manual jimny, does it make any difference that its an automatic and can i use the starter motor also any other info help tips would be appreciated,
Hopefully the photo of the engine has uploaded
Cheers mark
  • suzukisam
11 years 9 months ago #137285 by suzukisam
Replied by suzukisam on topic Older g16b conversion help
My friend has same engine and i have just put a g16b in mine i was looking at his it looks the same except the head is different as its got pick up point on the back where as the one in the pic is a dizzy cap rocker cover different too . Probably need the head then just use jimny inlet exhaust etc..
  • Markrush33
11 years 9 months ago - 11 years 9 months ago #137289 by Markrush33
Replied by Markrush33 on topic Older g16b conversion help
I saw your posts you put up about doing yours, so you think i need to change the heads over do you!!! What do you mean when you say pick up point
Last edit: 11 years 9 months ago by Markrush33.
11 years 9 months ago #137292 by j999pre
Replied by j999pre on topic Older g16b conversion help
For the cam sensor, you may be able to just swap the cam shaft and rocker cover?
Grey pick up Jimny
  • Markrush33
11 years 9 months ago #137294 by Markrush33
Not the straight forward swap i thought then
  • suzukisam
11 years 9 months ago #137302 by suzukisam
Doubt it would be to much work to be honest , i would need to see back of the head on my mates vit but there same engine code just get there spark a different way so cant see it been to hard
