A/T Tyre Efficiency
- BigAndy
robs5230 wrote:
you need to make sure that either you or others with you know the lanes before attempting them. the standard duellers would not be my choice for laning at allBigAndy wrote: At the minute my Jimny is factory standard with Bridgestone H/T road tyres. I plan to do some green laning but don't really want to spend a hell of a lot more in fuel. I understand the fuel bill probably will go up but want to keep the rise to a minimum.
Yes that's why I'm looking at A/T tyres.
As for the laning, I'm hoping to make friends with someone that knows them around Yorkshire so me and my brother can go with them.
- BigAndy
Rhinoman wrote: If you go onto one of the big internet tyre vendors then you can check the Euro tyre ratings for each tyre. For each type of tyre the ratings often vary with diameter and width as well so you need to be thorough. There doesn't seem to be much difference between ATs and MTs and the most efficient that I could find were Dunlop Grand Trek ATs; in Jimny sizes they are well rated for wet weather behaviour as well, the Bridgestone H/Ts are probably the worst wet weather tyre I've ever had.
They've not done too bad in wet weather in all honesty. I'm a fairly steady driver in my Jimny though to be fair.
- wombat
just changed for a later model and finding the same problem with the standard tyres, so when funds allow the first mod will be to fit at tyres
- Welsh1
- rayz_x
Ray
