A/T Tyre Efficiency
- BigAndy
17 Oct 2014 15:31 #126756
by BigAndy
A/T Tyre Efficiency was created by BigAndy
I'm not sure if this can be classes as 'technical' but is there such thing as a fuel efficient A/T tyre?
17 Oct 2014 15:48 #126758
by robs5230
standard jimny - for now
Replied by robs5230 on topic A/T Tyre Efficiency
i'm not sure of the mpg with OE tyres but i run hankook dynapro atm rf10 all terrains and i'm returning 35mpg. not bad for a proper 4x4.
all all terrains should in theory be worse on mpg than standard road tyres and the all terrains will be better than muds.
it really depends on what you use your vehicle for.
The following user(s) said Thank You: BigAndy
- BigAndy
17 Oct 2014 16:05 #126759
by BigAndy
Replied by BigAndy on topic A/T Tyre Efficiency
At the minute my Jimny is factory standard with Bridgestone H/T road tyres. I plan to do some green laning but don't really want to spend a hell of a lot more in fuel. I understand the fuel bill probably will go up but want to keep the rise to a minimum.
- handybutton
17 Oct 2014 16:56 #126762
by handybutton
Replied by handybutton on topic A/T Tyre Efficiency
Your lucky im running same tyres and only get 30mpg on average
17 Oct 2014 17:20 #126765
by robs5230
the size of the tyres and the effext on the gearing is also a factorhandybutton wrote: Your lucky im running same tyres and only get 30mpg on average
17 Oct 2014 17:22 #126766
by robs5230
you need to make sure that either you or others with you know the lanes before attempting them. the standard duellers would not be my choice for laning at allBigAndy wrote: At the minute my Jimny is factory standard with Bridgestone H/T road tyres. I plan to do some green laning but don't really want to spend a hell of a lot more in fuel. I understand the fuel bill probably will go up but want to keep the rise to a minimum.
