A/T Tyre Efficiency
  • BigAndy
12 years 1 month ago #126756 by BigAndy
A/T Tyre Efficiency was created by BigAndy
I'm not sure if this can be classes as 'technical' but is there such thing as a fuel efficient A/T tyre?
12 years 1 month ago #126758 by robs5230
Replied by robs5230 on topic A/T Tyre Efficiency
i'm not sure of the mpg with OE tyres but i run hankook dynapro atm rf10 all terrains and i'm returning 35mpg. not bad for a proper 4x4.
all all terrains should in theory be worse on mpg than standard road tyres and the all terrains will be better than muds.
it really depends on what you use your vehicle for.
standard jimny - for now
The following user(s) said Thank You: BigAndy
  • BigAndy
12 years 1 month ago #126759 by BigAndy
Replied by BigAndy on topic A/T Tyre Efficiency
At the minute my Jimny is factory standard with Bridgestone H/T road tyres. I plan to do some green laning but don't really want to spend a hell of a lot more in fuel. I understand the fuel bill probably will go up but want to keep the rise to a minimum.
  • handybutton
12 years 1 month ago #126762 by handybutton
Replied by handybutton on topic A/T Tyre Efficiency
Your lucky im running same tyres and only get 30mpg on average
12 years 1 month ago #126765 by robs5230
handybutton wrote: Your lucky im running same tyres and only get 30mpg on average
the size of the tyres and the effext on the gearing is also a factor
12 years 1 month ago #126766 by robs5230
BigAndy wrote: At the minute my Jimny is factory standard with Bridgestone H/T road tyres. I plan to do some green laning but don't really want to spend a hell of a lot more in fuel. I understand the fuel bill probably will go up but want to keep the rise to a minimum.
you need to make sure that either you or others with you know the lanes before attempting them. the standard duellers would not be my choice for laning at all
Time to create page: 0.101 seconds
