rear axle locking
10 Aug 2014 22:28 #121732 by Johnniehec
Replied by Johnniehec on topic rear axle locking
Is it in four wheel drive?
  • ddaann88
10 Aug 2014 22:31 #121734 by ddaann88
Replied by ddaann88 on topic rear axle locking
thanks for help yes sorry I meant the inside tyre spinning :silly: , not sure if its to do with brakes or not because it only changed when I lifted it. and I don't have much down travel still need to get some lifted shocks for it, if this could be the case
  • ddaann88
10 Aug 2014 22:32 #121735 by ddaann88
no it happened when it was in 2wd although haven't seen if its any different in 4wd
11 Aug 2014 19:49 - 11 Aug 2014 19:56 #121791 by Rhinoman
Replied by Rhinoman on topic rear axle locking
ddaann88 wrote: thanks for help yes sorry I meant the inside tyre spinning :silly: , not sure if its to do with brakes or not because it only changed when I lifted it. and I don't have much down travel still need to get some lifted shocks for it, if this could be the case
If its less than around 2" then the inside tyre may try to lift off the ground while cornering so you're losing grip and its spinning.
Last edit: 11 Aug 2014 19:56 by Rhinoman.
12 Aug 2014 15:18 #121843 by facade
Replied by facade on topic rear axle locking
You have lifted the car, so it is going to have more body roll in corners, and will try to lift the inside tyre which will spin if you provoke it.
Either go slower around corners, or don't turn the steering wheel so far and go wider. ;)
If you get it sliding outwards on a corner, when the tyres regain grip you can highside* it over onto its side which is somewhat embarrassing :blush: Do be careful until you are used to how it handles now.
*ask a motorcyclist
Time to create page: 0.088 seconds
