rear axle locking
- ddaann88
06 Aug 2014 20:45 #121452
by ddaann88
rear axle locking was created by ddaann88
after fitting a lift kit to my jimny I took it for a drive (on gravel) and when ever I went round a corner the wheel on the outside of the turn would spin, like it has a welded diff but it never did this before I lifted it, anyone know why this could be?
- Bits4Vits
07 Aug 2014 04:44 #121476
by Bits4Vits
Replied by Bits4Vits on topic rear axle locking
Handbrake cables are too tight and are pulling the brakes on?
10 Aug 2014 15:08 #121694
by facade
Replied by facade on topic rear axle locking
Are you sure it is the one on the outside?
I'd expect the higher roll centre to take some of the weight off the inside tyre (and put it onto the outside one), and as the inside one is the one that has to go slower, I'd expect it to spin first.
(I'd expect the inside wheel to spin with a welded diff anyway, as it is supposed to be going slower than the on on the outside, as it has less far to go, and the welded axle means both go at the same speed all the time)
10 Aug 2014 18:58 #121713
by Rhinoman
Replied by Rhinoman on topic rear axle locking
Are your shocks long enough? when you jack it up how much down travel do you have?
10 Aug 2014 19:13 #121715
Replied by mlines on topic Re:rear axle locking
As facade says can you confirm the side as I would expect it to be the wheel on the inside of the turn
Sent from my Nexus 5 using Tapatalk
- suzuki jimny fella
10 Aug 2014 20:52 #121718
by suzuki jimny fella
Replied by suzuki jimny fella on topic rear axle locking
brake balance not got braket might be that if not got one
Time to create page: 0.106 seconds
