rear axle locking
  • ddaann88
12 years 3 months ago #121452 by ddaann88
rear axle locking was created by ddaann88
after fitting a lift kit to my jimny I took it for a drive (on gravel) and when ever I went round a corner the wheel on the outside of the turn would spin, like it has a welded diff but it never did this before I lifted it, anyone know why this could be?
  • Bits4Vits
12 years 3 months ago #121476 by Bits4Vits
Replied by Bits4Vits on topic rear axle locking
Handbrake cables are too tight and are pulling the brakes on?
12 years 3 months ago #121694 by facade
Replied by facade on topic rear axle locking
Are you sure it is the one on the outside?
I'd expect the higher roll centre to take some of the weight off the inside tyre (and put it onto the outside one), and as the inside one is the one that has to go slower, I'd expect it to spin first.
(I'd expect the inside wheel to spin with a welded diff anyway, as it is supposed to be going slower than the on on the outside, as it has less far to go, and the welded axle means both go at the same speed all the time)
12 years 3 months ago #121713 by Rhinoman
Replied by Rhinoman on topic rear axle locking
Are your shocks long enough? when you jack it up how much down travel do you have?
12 years 3 months ago #121715 by mlines
Replied by mlines on topic Re:rear axle locking
As facade says can you confirm the side as I would expect it to be the wheel on the inside of the turn
Sent from my Nexus 5 using Tapatalk
  • suzuki jimny fella
12 years 3 months ago #121718 by suzuki jimny fella
Replied by suzuki jimny fella on topic rear axle locking
brake balance not got braket might be that if not got one
