dohc engine problem
  • jonesyba420
12 years 6 months ago #115677 by jonesyba420
Replied by jonesyba420 on topic dohc engine problem
Common problem on the DOHC........its just one of those things a sensor failing, its a cheap and easy fix so not really a problem.
12 years 6 months ago #115685 by j999pre
Replied by j999pre on topic dohc engine problem
Very common, the fan shroud was altered on later jimnys to provide more cooling.
I have a brand new sensor still boxed if your looking for one
Grey pick up Jimny
  • suzuki jimny fella
12 years 5 months ago #115703 by suzuki jimny fella
Replied by suzuki jimny fella on topic dohc engine problem
Hi all just had a quote on the sensors 80 for crank and cam if i replace the two sensors will i need to reset any thing with a code reader or is it the case if just unbolt and replace the two new sensors job done as there is no lights on dash thanks for your help guys hope this solves my problem with my baby lol :-)
12 years 5 months ago #115709 by suzuki jimny fella
Sorry for all the questions guys :-) but do you need to disconnected the Batt before you unplug the sensors thanks
  • jonesyba420
12 years 5 months ago #115711 by jonesyba420
Its probably just the crank sensor so id just replace that first rather than both.
Cant remember if I disconnected the battery and no you dont need to reset anything just simply plug and play.
12 years 5 months ago #115712 by Rhinoman
Replied by Rhinoman on topic dohc engine problem
You don't have to disconnect the battery, just make sure that the ignition is off.
Time to create page: 0.106 seconds
