dohc engine problem
- suzuki jimny fella
12 years 5 months ago #115602
by suzuki jimny fella
dohc engine problem was created by suzuki jimny fella
Hi all was out today going to a play day and my jimny started to cut out intermittently then started to run ok was out for few hours then on way home the same thing happen again and cut out so check all electrics under the bonit all seems to be ok she started back up up then drove home 10miles any idea what problem i have guys any of you had same problem
- jonesyba420
12 years 5 months ago #115603
by jonesyba420
Replied by jonesyba420 on topic dohc engine problem
Does the rev counter go mental?and the car with a padlock light flash on the dash?
My guess would be crank shaft sensor, plenty of info on here that a quick search should show.
12 years 5 months ago #115604
Replied by suzuki jimny fella on topic dohc engine problem
That's what happen mate 3 times is this the crank senser the one behind the altanator have you guys had this problem is the senser braking down
- jonesyba420
12 years 5 months ago #115607
by jonesyba420
Sounds the same as the fault I had, theres a simple test: take a squirty bottle of water out with you and when the car faults LEAVE IT RUNNING and squirt water on the sensor (hiding under the alternator) if normal running resumes theres the fault. The sensors get old and overheat..........bout £20-30.
- jtayl153
12 years 5 months ago #115608
by jtayl153
Replied by jtayl153 on topic dohc engine problem
I get nervous reading some of these posts. Our Jimnys are tough little cars but it seems theres a lot that can go wrong with them...
I guess all we can do is make sure the maintenance is done regularly (I change my oil every 5000km), dont do anything dumb, and hope for the best....
12 years 5 months ago #115643
has any one had same problem
Time to create page: 0.110 seconds
