dohc engine problem
12 years 5 months ago #115714 by Busta
Replied by Busta on topic dohc engine problem
jtayl153 wrote: I get nervous reading some of these posts. Our Jimnys are tough little cars but it seems theres a lot that can go wrong with them...
I guess all we can do is make sure the maintenance is done regularly (I change my oil every 5000km), dont do anything dumb, and hope for the best....
This is pretty much the only common engine fault and is cheap and easy to fix. Regular maintenance won't prevent it and it's not caused by being dumb but it is an easy problem to drive-around until you can get it fixed. Mine does it if I drive at more than 75 mph for 10 minutes or so. I let it cool for a minute then don't go over 70 and it runs fine again. New sensor arrived in the post this morning.
If this scares you, look up some common faults with modern diesel cars and the repair costs!
  • jonesyba420
12 years 5 months ago #115715 by jonesyba420
Replied by jonesyba420 on topic dohc engine problem
When mine was failing I couldnt travel at anything above 55mph for any prolonged amount of time but it would sit at 50 all day long without faulting.
  • suzuki jimny fella
12 years 5 months ago #115811 by suzuki jimny fella
Replied by suzuki jimny fella on topic dohc engine problem
Just fitted new crank sensor time will tell if we have solved it guys thanks
12 years 5 months ago #115911 by suzuki jimny fella
All is well think its fixed guys thanks
Time to create page: 0.090 seconds
