doors locks
12 Apr 2014 09:30 - 12 Apr 2014 09:33 #111975
by facade
Replied by facade on topic doors locks
Google toad alarm instructions
There are installation instructions that can turn off the autolock feature, but you need a pin code
However, the standard instructions tell you
Valet Override
The alarm system incorporates a valet override, which suspends alarm operation but still allows you to use the radio key for locking.
This is recommended when your vehicle is serviced or repaired, as the settings are remembered even when the battery is disconnected. Valet override mode is entered by disarming the system, turning the ignition on and pressing and holding buttons 1 and 2 for 3 seconds the indicators will flash 3 times as confirmation. The LED will emit a slow orange flash while in valet mode. The system will stay in this mode until the above procedure is repeated. The radio key can be used to lock and unlock the vehicle.
Toad alarms are very good, a shame to disable it completely.
Marky: Good tip about the valet override
, I'll see if my alarm has one, drives me nuts when working on the car.
Valet Override
Last edit: 12 Apr 2014 09:33 by facade.
- richardp
12 Apr 2014 12:39 - 12 Apr 2014 13:07 #111985
by richardp
Replied by richardp on topic doors locks
do you mean the buttons on the key fob? and what LED will emit a slow orange flash? sorry to sound stupid but I guess I am!!
BTW I don't need to lock the doors at all.
I'll try to add some pic's
Is this the box? only one I could find under the dash, unless its this black one under the bonnet, passenger side?
Last edit: 12 Apr 2014 13:07 by richardp. Reason: more
12 Apr 2014 13:26 #111987
by facade
If your fob looks like this
otherwise, you will have to find the model number
There must be an LED on/in the dash or a blank switch somewhere that flashes comfortingly when the alarm is active
Then once valet mode is engaged and you have unlocked the car, don't press any buttons on the fob
The black box under the bonnet is the alarm. The one under the dash is something vital for the normal running of the car.
Best not to mess with any wires or boxes
richardp wrote: do you mean the buttons on the key fob?
richardp wrote: and what LED will emit a slow orange flash? sorry to sound stupid but I guess I am!!
richardp wrote: BTW I don't need to lock the doors at all.
The following user(s) said Thank You: richardp
- markyp2000
12 Apr 2014 14:12 - 12 Apr 2014 14:15 #111989
by markyp2000
Replied by markyp2000 on topic doors locks
The black box under the bonnet follow the wires inside the car to the alarm box the one you have pic is the engine ecu dont touch that lol the box your looking for will have 2 to 5 plugs and its 4" x 3" x 1" thick and will have toad onit it may be up under the dash on the drivers side near the fues box hope this helps
also try looking here if this is the alarm you have it may help
forum.kitecrowd.com/bar-zone/toad-a101-c...-fitting-156949.html
Last edit: 12 Apr 2014 14:15 by markyp2000.
- richardp
12 Apr 2014 17:33 - 12 Apr 2014 17:39 #112002
by richardp
Thanks!
I was wrong about the key fog as it does have another little tag with a number on it.
and just two buttons and says "Toad"
I've added some more pic,s the fuse box is under the bonnet, cant find the toad alarm box.
The photo with the little red light on the left, is that the LED you refer to?
Last edit: 12 Apr 2014 17:39 by richardp. Reason: more
- jonesyba420
12 Apr 2014 17:49 #112004
by jonesyba420
Replied by jonesyba420 on topic doors locks
Yea that is the led in question.
There is 2 fuse boxs, 1 in the engine bay and 1 under the dash as mentioned.
Get on your back in the drivers footwell and look up under the dash for any boxs that look aftermarket (I mounted mine on top of the cubby hole left of the steering colum), try following the wires from the led.
