doors locks
12 Apr 2014 18:29 #112013
by facade
Replied by facade on topic doors locks
The tag on the keyring is the number of the ignition key: you use this to order a new key from Suzuki that will turn in the lock, but not start the car as it then has to be programmed to the ecu.
Why not try the valet mode instruction? Either it works or it doesn't and if it does it saves a lot of messing about.
The following user(s) said Thank You: richardp
- richardp
12 Apr 2014 19:27 - 12 Apr 2014 19:55 #112019
by richardp
Replied by richardp on topic doors locks
Last edit: 12 Apr 2014 19:55 by richardp. Reason: .
12 Apr 2014 20:08 #112021
by facade
That is the alarm, you need the model number off the label that you can't quite read if the two button trick doesn't work.
The led might not flash orange, looks like yours is a red only one, but the indicators should do something to tell you it has worked.
- richardp
12 Apr 2014 20:11 #112022
by richardp
OK! thanks, I better not try it too early as the neighbours might be sleeping in, I shall give it a go.
12 Apr 2014 21:59 #112047
by Rhinoman
Replied by Rhinoman on topic doors locks
I don't know about the TOAD but on some alarms that I've had you occasionally need to resync the remote with the alarm, there is a button pressing sequence to do that. Recently there have been a number of people having problems with TOAD alarms, it may be that they are just failing from old age.
Time to create page: 0.115 seconds
