doors locks
- richardp
12 years 7 months ago #111934
by richardp
doors locks was created by richardp
Hi! I was recently acquired a 2002 Suzuki Jimny, I live on an off shore Island, we have no crime I don't need the doors to lock when the ignition is on or the alarm, I'm told that there is no way of disarming the alarm unless your a suzuki technician, but I wonder If I can stop the doors locking? take the fuse out maybe?
hope you can help
cheers
hope you can help
cheers
- markyp2000
12 years 7 months ago #111935
by markyp2000
Replied by markyp2000 on topic doors locks
Pull the fuse on the alarm as far as im awere jimnys of your age didnt come with alarms so may be an aftermarket fitment
12 years 7 months ago #111960
by facade
Replied by facade on topic doors locks
Try the fuse as Marky suggests, but cover your ears first :ohmy: if it is an aftermarket alarm/immobiliser it may simply go off, and then the car will never start again until the fuse is replaced and the alarm reset.
Some alarms have a keyhole so you can turn them off - there will be a key on the ring that you don't know what it does.
If it is an immobiliser alarm, they are easy enough to remove and restore the wiring, come back if you find that it is.
The following user(s) said Thank You: richardp
- jonesyba420
12 years 7 months ago #111962
by jonesyba420
Replied by jonesyba420 on topic doors locks
The key hole is usually on the siren, well it is on my aftermarket alarm.
Always forget to turn it off when I disconnect the battery and end up s*#$×¥g myself lol.
- richardp
12 years 7 months ago #111964
by richardp
Replied by richardp on topic doors locks
OK! I know nothing about this sort of thing but It says on the window that its a toad alarm and when it goes off you stop it by pressing the green button on the key fob, there is no other key on the fob.
Also as soon as we get in and start the engine the doors lock and if we want to get out we have to turn off the engine, anyway around this?
cheers and thanks for the replies so far.
- markyp2000
12 years 7 months ago #111967
by markyp2000
Find the alarm box under the dash get the model number google the wiring diagrame and cut the locking wire
the box my be behind the glove box or near the fues box you will know what one it is due to the shoddy wiring to it and as a stater its not the shiny box behind the glove box and being a toad there should be a valet switch some where
Time to create page: 0.103 seconds
