Modular wheels
MS wrote: Hi Casey,
You say you were advised 15x8 only on lifted Jimny, but I'm running 15X8 wheels with 215/70 R15 tyres on my otherwise standard 2010 Jimny and have no issues with rubbing either in normal driving (even at full lock) or when doing light off-roading (muddy tracks with ruts and puddles).
Kind regards
Mark
Hi Mark,
Mine's a 2005, is a 2010 the same design? (See picture) ie is it likely to have the same same clearance around the arches?
- Jutwit
I got MUDs on mine that size, and it ain't lifted (and never will be) no rubbing at all, mine a2008 oneMS wrote: Hi Casey,
Kind regards
Mark
jonesyba420 wrote: King pins are simple enough just dirty (you will need pleanty of blue roll!), familiarise yourself with the guide and soak the necessary bolts in wd40 or something similar for a few days prior to make things abit easier. make sure you have the right tools you need, normal socket set, E sockets, breaker bar and ball joint splitter will help to. Best to replace the diff oil aswell. Do one side at a time, youll notice theres a couple of steps in the guide you can miss.
This may sound like a stupid question, but how do I change the diff oil?
- Yellostreak
you use a 3/8 square drive bar or ratchet to undo the fill and drain plugs.. undo the fill plug first because if its stuck then you don't want to be taking out the drain as there is no way to get the oil back in easily..
filling it back up make obviously put the drain in first then fill through the fill plug till it runs out the hole then its full up..
drain is at the bottom, fill is half way up the casing. spray with some penetrating oil the day before as they may be tight.
Drain before you do your kingpins then fill after you've done them as you should change the axle seal at the same time, no tools needed for the seal just pull it out then push a new one back in.
Yellostreak wrote: spray with WD40 the day before as they may be tight.
I've never been fond of WD40. I like if anything Plusgas but usually I end up shifting these sorts of plugs with heat.
- L7kvv
Ive changed the kingpins on both sides of mine and for the love of god i couldnt get the old seals removed
