Modular wheels
12 years 9 months ago #104179 by Casey
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by Casey on topic Modular wheels
jonesyba420 wrote: King pins are simple enough just dirty (you will need pleanty of blue roll!), familiarise yourself with the guide and soak the necessary bolts in wd40 or something similar for a few days prior to make things abit easier. make sure you have the right tools you need, normal socket set, E sockets, breaker bar and ball joint splitter will help to. Best to replace the diff oil aswell. Do one side at a time, youll notice theres a couple of steps in the guide you can miss.
Thanks Jonesyba420 but what are E sockets?
  • jonesyba420
12 years 9 months ago #104182 by jonesyba420
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by jonesyba420 on topic Modular wheels
The E socket is a star shape, used to undo the bolts holding the hub on.if you look at the wheel the hub sticks through the centre its the ring of little bolts around that.think its a E10.
  • MS
12 years 9 months ago #104184 by MS
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by MS on topic Modular wheels
Hi Casey,
You say you were advised 15x8 only on lifted Jimny, but I'm running 15X8 wheels with 215/70 R15 tyres on my otherwise standard 2010 Jimny and have no issues with rubbing either in normal driving (even at full lock) or when doing light off-roading (muddy tracks with ruts and puddles).
Kind regards
Mark
  • helijohn
12 years 9 months ago #104200 by helijohn
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by helijohn on topic Modular wheels
I hated doing the job but then I hate most mechanical jobs. ;) DIY is cheap though so needs must. :whistle:
  • helijohn
12 years 9 months ago #104201 by helijohn
jonesyba420 wrote: The E socket is a star shape, used to undo the bolts holding the hub on.if you look at the wheel the hub sticks through the centre its the ring of little bolts around that.think its a E10.
It's a torx innit...............he needs size E10??
  • helijohn
12 years 9 months ago #104204 by helijohn
MS wrote: Hi Casey,
Kind regards
Mark
Yeah, I had 225 70 15 on 8" rims when I first got mine. Looked nice too but the tyres were finished.
Time to create page: 0.129 seconds
