SOFT SUSPENSION
- jonesyba420
03 Feb 2014 08:35 #103157
by jonesyba420
Replied by jonesyba420 on topic SOFT SUSPENSION
I recently re done my tyre pressures dropped the fronts from 26psi to 23psi and it made a world of difference much smoother ride.
03 Feb 2014 09:01 #103161
by Obarno
Replied by Obarno on topic SOFT SUSPENSION
If I'm going to spend a little while driving tracks I drop the pressures down to about 14psi and that makes a big difference not only to the ride, but also to traction over rocks, mud etc. Just blow them back up when you want to drive home.
- Jimny J
03 Feb 2014 15:25 #103189
by Jimny J
Replied by Jimny J on topic SOFT SUSPENSION
With regards to the rear pogo effect, are you running a full 2in lift kit with shocks and springs? Or spring spacers with the standard shocks? Only ask as I have spacers and standard shocks and I found the shock relocation brackets completely cured the bounce.
- Jimny J
03 Feb 2014 15:27 - 03 Feb 2014 15:28 #103191
by Jimny J
Tyre pressure makes a huge difference as already mentioned, im keep mine at 20psi up front and 17 on th3 rear. Drives beautifully now and not noticed any adverse effects on road. Thats with 235 75 15 mt's.
Last edit: 03 Feb 2014 15:28 by Jimny J.
- TomDK
03 Feb 2014 16:14 #103198
by TomDK
What suspension are you running ?
Replied by TomDK on topic SOFT SUSPENSION
Millzy wrote: does anyone know of any springs that could make my suspension soft for more bending Easyer because I have a lot of rocky areas to 4x4 but the suspention is very stiff and end up bouncing a around everywere
- jonesyba420
03 Feb 2014 16:23 #103199
by jonesyba420
and the debate begins............................. :whistle:
:laugh: :laugh: :laugh:
TomDK wrote: What suspension are you running ?
Time to create page: 0.091 seconds
