SOFT SUSPENSION
- TomDK
03 Feb 2014 16:46 - 03 Feb 2014 16:54 #103203
by TomDK
Replied by TomDK on topic SOFT SUSPENSION
Not at all.
But often people get suspension all wrong and look at springs when they should look at shocks and vice versa.
Also for some reason a number of forum users want as soft shocks as possible which makes no sense for offroading.
Suspension talk is science, and I'm no expert. Just trying to get an understanding of how it works as I'm looking for some good shocks for my own Jimny, probably either Bilstein or Fox
Last edit: 03 Feb 2014 16:54 by TomDK.
- k08888
04 Feb 2014 08:05 #103304
by k08888
Replied by k08888 on topic SOFT SUSPENSION
If you want soft and comfort ride; go with the trailmaster comfort springs and shocks. Little more € to spend, but they are worth it.
I spend my money first on cheap shock, and then i pay good shocks, so dont buy es 1000 shocks, they are pretty stiff.
- jonesyba420
04 Feb 2014 08:27 #103307
by jonesyba420
Replied by jonesyba420 on topic SOFT SUSPENSION
How much softer is the comfort kit compared to the jimnys standard suspension? Is there much difference between the comfort and sport trailmaster setup?
The pro comps are designed for a heavier US truck whereas the trailmaster are designed for the jimny.
04 Feb 2014 12:12 #103323
by robs5230
standard jimny - for now
Replied by robs5230 on topic SOFT SUSPENSION
i'm running a full 3" lift with rear shock relocators. the shocks are shafted. new pair on order and here soonJimny J wrote: With regards to the rear pogo effect, are you running a full 2in lift kit with shocks and springs? Or spring spacers with the standard shocks? Only ask as I have spacers and standard shocks and I found the shock relocation brackets completely cured the bounce.
- Millzy
05 Feb 2014 12:45 #103462
by Millzy
Replied by Millzy on topic SOFT SUSPENSION
hi mate im running a 3inch procomp springs and shocks setup sorry haven't been on to reply
- TomDK
05 Feb 2014 13:30 #103465
by TomDK
What shocks? ES1000, ES3000 or.. ??
Time to create page: 0.182 seconds
