SOFT SUSPENSION
  • jonesyba420
05 Feb 2014 16:09 #103493 by jonesyba420
Replied by jonesyba420 on topic SOFT SUSPENSION
TomDK wrote: So you just take what one person write as fact?
definately not buddy..........................
but then again i am taking what you say as fact ;)
you seem to know your stuff tho :)
just trying to learn new stuff and hopefully help others with the info gained from my questions.
i know suspension is a complex thing to get right and set up properly and that "proper" set ups cost alot of money, its the same with everything you get what you pay for! pro comp wont do the same vehicle research as koni will, same with lowering springs for normal cars you can get cheap ones that will ride shite or you can buy eibach ones which are twice-three times as much but ride properly.
  • TomDK
05 Feb 2014 16:20 #103496 by TomDK
Replied by TomDK on topic SOFT SUSPENSION
Don't I'm no expert :D
I only have a rough idea about how I want my shocks set up. But will probably have to pay some experts one day, when I get proper suspension :)
Also you're right. Eibach springs are good quality. But what makes them better than other springs, I don't know. Perhaps they last longer, can be offered in custom rates, progressive or whatever .. ? :)
  • jonesyba420
05 Feb 2014 16:26 - 05 Feb 2014 16:28 #103500 by jonesyba420
TomDK wrote: Also you're right. Eibach springs are good quality. But what makes them better than other springs, I don't know. Perhaps they last longer, can be offered in custom rates, progressive or whatever .. ? :)
i believe they actually manufacture the springs for the specific car rather than just a generic "this fits this" so they are the correct spring rate etc. i had eibach 25mm lowering springs on my last car and they made the world of difference to handling but didnt really change the ride quality (was just as firm as before) whereas cheap lowering springs are just shorter and much firmer creating a harsh ride.
more research and development equals a more expensive end product.
shame we cant get height and shock adjustable coilovers, then we could raise and lower stiffen soften our rides at will.
Last edit: 05 Feb 2014 16:28 by jonesyba420.
  • Olucas91
05 Feb 2014 20:07 #103548 by Olucas91
Replied by Olucas91 on topic SOFT SUSPENSION
I've just put AVO adjustable shocks on mine with a 3" lift and you can tell the difference between the settings. On there highest it is a very harsh ride and there softest it's abit softer than stock. May be worth a look if you use it as a daily. Got mine from jimnybits
  • 410shotgun
05 Feb 2014 20:22 #103551 by 410shotgun
Replied by 410shotgun on topic SOFT SUSPENSION
the spring I fitted were sachs both rear springs the same
but my mate got some off the net suplex the drivers side is a thicker stronger spring
Time to create page: 0.111 seconds
