KEY PROGRAMMING
  • Neil54
6 years 10 months ago #216722 by Neil54
Replied by Neil54 on topic KEY PROGRAMMING
I have just bought a new central locking fob for my key, the two buttons.
It was supplied by my local Suzuki dealer and cost £135 programmed.
I had to take all my keys with me. Didn't take long.
  • prolecs
6 years 2 months ago #227613 by prolecs
Replied by prolecs on topic KEY PROGRAMMING
I believe the chip is a D46 (433MHz) but can't confirm this as I don't have the programmer or OBDSTAR. My 2010 Aussie Jimny has B05519 stamped on the chip but no D46 marking. Experience with Mk4 Astra key programming - it uses "PCF7936AS Auto key transponder chip ID46" and these have no D46 markings either. But do have the PCF .... number. You can buy blank chips online very cheaply.
6 years 2 months ago #227635 by yakuza
Replied by yakuza on topic KEY PROGRAMMING
The immo chip type for the Jimny is at least three different series of chips and if you do not have the correct address range for your ECU/year you cannot program that chip to the ECU.
I tried to copy my own chip address to blank chips, tried to buy chips from ebay but to no effect, they are not programmable to the ECU. Might just admit I am not a criminal i guess :)
Best to just do this at a Suzuki dealer as there is a limit to how many keys you need so the cost is lower and hassle much less.
I tried just for the fun of it also but when i failed it was not so fun :)
Nowadays my aftermarket key fob sometimes fails to register the chip in the ignition antenna so the immo kicks in and blinks and no ignition. have to remove the key and try again and then it starts.
happens from time to time..
6 years 2 months ago #227636 by yakuza
Actually I would like a keyless go like the newer Suzukis. there is aftermarket kits you can buy with RFid readers and often you allready got a RFid chip for your door or work or something so if you can program that same door chip to your car would be nice.
  • Kicomoco
6 years 2 months ago #227884 by Kicomoco
Replied by Kicomoco on topic KEY PROGRAMMING
Does anybody know how to identify if your Jimny has the receiver for remote locking?
  • prolecs
5 years 3 months ago #237180 by prolecs
Well you could check the receiver module up behind the dash - 37190-81A70 seems with keyless entry for type 6 and 7 and maybe others (without is 38700-84F30).
Time to create page: 0.114 seconds
