KEY PROGRAMMING
11 Apr 2018 17:55 #191583 by Bosanek
Replied by Bosanek on topic KEY PROGRAMMING
I decided to continue in this topic instead of making a new one, as I believe that I have a similar situation.
It is a petrol Jimny made in 2013 in Japan (type 9 model).
It originally had a standard key (no buttons on it) plus a separate remote controller for remote central locking of all vehicle's doors.
Well that remote controller thingy got lost.
Now the car can be (un)locked only by putting the key in a door lock, like in an old vehicle.
So, there are now two questions:
1. Where to obtain another remote controller (Suzuki dealers ask a high price ...)? Perhaps from a vehicle junkyard, or new aftermarket of the same quality?
2. How to program the new remote controller to the car?
11 Apr 2018 18:02 #191584 by Riccy
Replied by Riccy on topic KEY PROGRAMMING
No eBay APP ID and/or Cert ID defined in Kunena configurationDont know about programming it (auto electrical specialist?) but the key is easy to get:
12 Apr 2018 10:15 #191612 by yakuza
Replied by yakuza on topic KEY PROGRAMMING
I bought this or a similar item. It works and I can program my excisting keys in my 2005 jimny.
You will need the correct immo chips to program it to your car.
The following user(s) said Thank You: SpamJ
12 Apr 2018 10:17 #191613 by yakuza
remember that not all Jimnys have the reciever for the remote so on my car i could not program a remote even though the car data from suzuki said i could.
  • helijohn
12 Apr 2018 17:50 #191629 by helijohn
Replied by helijohn on topic KEY PROGRAMMING
yakuza wrote: remember that not all Jimnys have the reciever for the remote so on my car i could not program a remote
This has me a little confused because if you don't have the receiver then can't you simply use a non coded key?
13 Apr 2018 06:50 - 13 Apr 2018 06:55 #191648 by yakuza
The programmer is used for the immo chip, the small one below the key on the picture of the key above here.
There is an antenna/signal booster near the ignition key and your key (chip) have to be programmed to the ECU.
The reciever for the remote lock/unlock button sender is a different thing and not all jimnys have it.
I tried to use a key remote like the one above here but there is no reciever on my car.
I have installed an aftermarket reciever/key sender hooked up to the wiring for the buttons in the door.
Last edit: 13 Apr 2018 06:55 by yakuza.
Time to create page: 0.323 seconds
