What is this cable?
  • greenjimny
14 Dec 2013 22:47 #96086 by greenjimny
Replied by greenjimny on topic What is this cable?
benny wrote: you can see the cable in this pic
thats the clutch cable mate
  • zuki andy
15 Dec 2013 00:16 #96094 by zuki andy
Replied by zuki andy on topic What is this cable?
maxw wrote: I took the front bumper off my jimny today and found this cable hiding inside it the front crossmember:
It came from down the drivers side of the engine bay and out past the front chassis mount:
Any idea what it is? & what shall I do with it?!
Also, I tried to remove my headlight by taking the two screws out, but it seemed to be still held in but didn't want to come when I tugged at it - any tips on removing them?
Cheers
My guess for the cable is somebody's put a braking system on it for towing it with a A frame. Have a look at the brake pedal see if the other end of the cable is looped around it.
15 Dec 2013 08:05 #96103 by kirkynut
Replied by kirkynut on topic What is this cable?
I've been frightened of breaking the plastic clips on my headlights but maybe I'll try the wd40 and a tug trick and see what happens.
  • Yellostreak
15 Dec 2013 09:24 - 15 Dec 2013 09:25 #96110 by Yellostreak
Replied by Yellostreak on topic What is this cable?
zuki andy wrote:
Looking like that great lump of steel its resting on is part of the towing A-Frame mounting hardware...
Last edit: 15 Dec 2013 09:25 by Yellostreak.
  • JuanGuillie
15 Dec 2013 11:51 #96125 by JuanGuillie
Replied by JuanGuillie on topic What is this cable?
I also think it 's part from a towing A-triangel.
The cable could be (or was been) connected underneath to the handbrakesystem.
I suppose it works like on a braked trailer, you have a secondary security braking-system.
The towed trailer (or Jimny) has a security cable, this cable has to be hooked on the towing vehicle.
When the towed trailer (or Jimny) should accidentelly brake loose (coming off from the tow-ball) this cable (when tensioned) will acctivate the brakes.
In this case the Jimny will be "handbraked" by the security cable (wich is probably the one on your pictures).
That is my opinion, but take a good look underneath and follow the cable, there also could be some bits missing and they didn't bother to take the cable away. ;)
  • Stu stu
15 Dec 2013 12:44 #96132 by Stu stu
Replied by Stu stu on topic What is this cable?
Why not get someone to pull the cable and try roll the car forward abit see if it moves :)
Time to create page: 0.109 seconds
