What is this cable?
- maxw
15 Dec 2013 17:31 #96164
by maxw
Replied by maxw on topic What is this cable?
Thanks for all the replies!
I think it must be from an A frame type set up - I've looked on the brake pedal and there is a cable coming to it which is bracketed on and goes through the bulkhead into the engine bay.
Id assume that it is the type used for a safety as otherwise the engine would need to be on to use the brakes easily.
I think i'll remove the cable just in case as I doubt I'll use it!
15 Dec 2013 17:51 #96173
by facade
Replied by facade on topic What is this cable?
Best to remove it if you don't want an A frame.
Most likely the A frame had an overrun brake, as the frame closes on the towcar it pulls that cable through a lever.
If it were for safety, all that would happen if the a frame broke away is the cable would pull on the footbrake, causing the cable to snap.
- 410shotgun
15 Dec 2013 20:34 #96248
by 410shotgun
Replied by 410shotgun on topic What is this cable?
it looks like a a frame brake cable to me and the brackets
I had to fit all that on mine and wire up the lights
for my a frame
for my a frame
- maxw
15 Dec 2013 21:29 #96270
by maxw
What did you use it for? is this for towing behind motorhomes and such?410shotgun wrote: it looks like a a frame brake cable to me and the brackets
for my a frame
16 Dec 2013 23:19 #96491
I'd say so but then it begs the question; what, if any, miles has it done like that? :ohmy:
Replied by helijohn on topic What is this cable?
maxw wrote: is this for towing behind motorhomes and such?
- maxw
17 Dec 2013 17:26 #96551
by maxw
Would this still go on the clock or not? I don't really mind as its done 100k anyway & is far from pristine!
Time to create page: 0.116 seconds
