What is this cable?
  • maxw
12 years 11 months ago #96072 by maxw
What is this cable? was created by maxw
I took the front bumper off my jimny today and found this cable hiding inside it the front crossmember:
It came from down the drivers side of the engine bay and out past the front chassis mount:
Any idea what it is? & what shall I do with it?!
Also, I tried to remove my headlight by taking the two screws out, but it seemed to be still held in but didn't want to come when I tugged at it - any tips on removing them?
Cheers
  • greenjimny
12 years 11 months ago - 12 years 11 months ago #96077 by greenjimny
Replied by greenjimny on topic What is this cable?
mate that looks awfy like a clutch cable , or handbrake cable !!! wtf?? ... the lamps are one push fit ball mounts , a swift tug shld see them off
cheers
does the clutch operate ??
Last edit: 12 years 11 months ago by greenjimny.
  • benny
12 years 11 months ago #96078 by benny
Replied by benny on topic What is this cable?
hi if you look at the back of the head light you will see two like pegs that hold it in place I got the wd40 quick spray. think I pushed it from the back first then got hold of the light and pulled it. I not know what cable is ?
  • maxw
12 years 11 months ago #96079 by maxw
Replied by maxw on topic What is this cable?
Does the clutch have two cables which go to it? As both the handbrake and clutch work perfectly! when you pull the inner cable you can hear something moving inside the bulkhead but I'm not sure what.
  • greenjimny
12 years 11 months ago #96082 by greenjimny
maxw wrote: Does the clutch have two cables which go to it? As both the handbrake and clutch work perfectly! when you pull the inner cable you can hear something moving inside the bulkhead but I'm not sure what.
no the clutch is one cable mate ..... the plot thickens lol some one has quite obviously retro fitted this cable for another purpose
on a closer look ... the two front mounts that are peices of tube ?! has it had a plow or summat on there ?? maybe a manual lift for this ?!
  • benny
12 years 11 months ago #96085 by benny
you can see the cable in this pic
Time to create page: 0.101 seconds
