Emissions failure - lambda reading
31 Oct 2013 20:08 #88804 by Rhinoman
Bad cat would usually give a high NOx reading, CO is more likely to be a bad O2 sensor, they have to be pretty bad to flag a MIL so you can't rely on that to indicate that its duff.
The following user(s) said Thank You: Mick C
  • Mick C
01 Nov 2013 07:32 - 01 Nov 2013 07:33 #88857 by Mick C
Replied by Mick C on topic Emissions failure - lambda reading
Thanks fellas B)
I'll have a good look at the exhaust - it's well past its best tbh.
I'll also have a look at the lambda sensor on the OBDII live data - I'm guessing the voltage fluctuation will indicate whether it's a duffer or not?
Last edit: 01 Nov 2013 07:33 by Mick C.
01 Nov 2013 18:46 #88922 by Rhinoman
The OBD2 tool will be too slow to get any real idea of how well the O2 is switching, check the fuel trims and the temperature sensors.
  • Mick C
01 Nov 2013 19:04 #88929 by Mick C
What am I looking for with the fuel trims and the temperature sensors?
01 Nov 2013 22:25 #88968 by Johnniehec
Our 2002 soft top failed on emissions, All readings sky high yet it we'd running fine and no lamp on . Replaced the manifold lambda with a universal one( you have to cut the wires and solder the plug on. Cost about £ 30 instead of £95+ from the dealers. Passed with flying colours.
John.
  • Mick C
02 Nov 2013 06:54 #88985 by Mick C
Johnniehec wrote: Our 2002 soft top failed on emissions, All readings sky high yet it we'd running fine and no lamp on . Replaced the manifold lambda with a universal one( you have to cut the wires and solder the plug on. Cost about £ 30 instead of £95+ from the dealers. Passed with flying colours.
John.
Thanks mate, that's good to know B)
