Emissions failure - lambda reading
02 Nov 2013 12:01 #89017
by Rhinoman
Replied by Rhinoman on topic Emissions failure - lambda reading
Check the temperature sensor readings when its been standing, they should both read ambient temperature. The fuel trims should be close to centre, if not there is an issue. If the trims indicate lean at low idle/low load but come back to centre at higher loads then that a fair sign of a vacuum leak.
- Mick C
08 Nov 2013 17:25 #89965
by Mick C
Replied by Mick C on topic Emissions failure - lambda reading
Had a new backbox and link pipe fitted earlier in the week, took it for another emissions test today and it passed! :woohoo:
Thanks for all the advice
Time to create page: 0.140 seconds
