Immobilser problems - please HELP !!
13 years 3 months ago - 13 years 3 months ago #77970
by Rhinoman
Replied by Rhinoman on topic Immobilser problems - please HELP !!
Those immobilisers are a bit awkward to work on, there are a couple of capacitors on the other side of the board to the wires that crack if you hand solder. I usually replace them with ceramics, back when the immo was designed ceramics weren't available in those sizes but fortunately things have progressed.
The immo is designed so it can't be bypassed, it can be temporarily disabled using an SDL interface or a main dealer scan tool but thats only really intended to allow your main dealer to collect it from you or to confirm an immo issue.
When I'm bench testing I usually push the key through the ring, it doesn't matter which way round, but if its sideways to the antenna then the magnetic field may not align with the antenna in the chip.
Last edit: 13 years 3 months ago by Rhinoman.
- Scutter
13 years 3 months ago #77977
by Scutter
Replied by Scutter on topic Immobilser problems - please HELP !!
I'm just hoping that they can fix it...
It did seem very odd that even after I reconnected the wires the damn thing still wouldn't work!
I take it that the antenna detects and reads the chip, which the immobilser compares to the code which it has been programmed with - and if they match sends a signal to the ECU which allows the car to start?
So, it can only really be that the antenna is not working at all, or the module has lost its code somehow?
I'm going to give them a call shortly and see if they have had chance to look at it. Typical eh! I've been using the motorbike for work for the last couple of weeks in the nice weather - and now I need the car as the rain is torrential - its not running !!!
13 years 3 months ago #78026
by Rhinoman
The immo checks the key code against the one that's stored in its memory and if its OK then it sends its own code to the ECU, if that matches the code stored in the ECU then the ECU will allow the engine to start.
- Scutter
13 years 3 months ago #78045
by Scutter
Thanks for that. So is it possible to repair the antenna, or get a replacement? or does it mean replacing the whole immobiliser module (if the antenna is US)?
13 years 3 months ago - 13 years 3 months ago #78048
by Rhinoman
The antenna can be replaced but its unlikely to be faulty, its just a wire coil, there could be a problem with the PCB if the caps are damaged. If theres static damage from touching the antenna then that goes straight into the TIRIS chip so that would be a replacement immo, the TIRIS chip and the processor are the only two parts that can't be economically replaced.
- Scutter
13 years 3 months ago - 13 years 3 months ago #78049
by Scutter
Very helpful - thank you. I'll give them a call again shortly to see what they have found.
If I need a new immobiliser unit - can you recommend a supplier, and how much would you expect to be paying for it?
Or are there any company's that repair them?
Sorry to bombard you, I bought this as a fun, but cheap second car for me to use when I'm not on the bike. I'm not so much a Jimny enthusiast - more a rain-avoiding biker
Last edit: 13 years 3 months ago by Scutter. Reason: typo
Time to create page: 0.092 seconds
