Immobilser problems - please HELP !!
13 years 2 months ago #80681 by Rhinoman
helijohn wrote: Might be worth asking a few awkward questions. Personally if I felt suitablyripped off I would not let it lie and not using a code reader (well) is one of those cases.
Well I just checked the FSM and it gives the same code DTC13 NO TRANSPONDER CODE TRANSMITTED OR COIL ANTENNA OPENED/SHORTED so it looks like the Tech 2 can't tell the difference. I'll run some bench tests because I'm sure that the immo itself transmits a different code. Personally if I suspected a key then I'd use another one next to the antenna and that should then throw a code not matched fault (DTC 21).
13 years 2 months ago #80684 by Rhinoman
Gosh the FSM is a bit odd on this one. Step 9 on the diagnostics is to use another key from the same vehicle, it doesn't suggest using a different key.
The FSM also has a different diagnostic procedure for a black key and a grey key yet they are the same system - both use a Texas 4C transponder and I've proven them to be interchangeable.
  • helijohn
13 years 2 months ago #80691 by helijohn
Replied by helijohn on topic Immobilser problems - please HELP !!
Rhinoman wrote: Gosh the FSM is a bit odd on this one. Step 9 on the diagnostics is to use another key from the same vehicle, it doesn't suggest using a different key.
This is getting curiouser and curiouser. ;)
Time to create page: 0.088 seconds
