Immobilser problems - please HELP !!
- Scutter
Dear Mr XXXXXX
Thank you for your email reference your recent repair.
I have discussed your concerns with both XXX and the technician who repaired your vehicle.
When we were presented with the vehicle the vehicle immobiliser was not being accepted by the key and the key would not code into the car. It would be impossible at this stage with no historical information to determine the actual fault. We could easily spend some considerable hours testing wiring and components however the most logical and most cost effective initial step is to obtain a new key and code it to the vehicle, this is the very start position from which we must work. I can assure you that alternative diagnostic time would have been well in excess of this. Once the technician was able to establish through the new key that there was a fault in the system it was far easier to diagnose the problem by following the technical wiring checks. This allowed us to repair the damaged component as cost effectively as possible. I hasten to add that the "repaired" component would have cost £387 + Vat to replace which we could have advised you of and charged had we been so way inclined.
To conclude we always follow the less expensive initial diagnostic route but the final outcome on wiring related issues can never be pre judged.
I am fully satisfied that my team have provided a satisfactory solution to your problem and resolved it in the most cost effective manner possible with information provided.
Regards
XXXXXXXXX
Group Managing Director
- Scutter
I appreciate the sentiment - but I know I'm not going to get anywhere with this, and life is just too short to waste the effort. Just going to take it on the chin and move on.
Its in for MOT in a couple of weeks so I'll probably be back on then posting more tales of woe
I hope that someone else faced with an immobilser issue and doesn't know what to do - see's my posts and then at least they'll have the heads-up for what to expect and look out for.
Many thanks for your help and comments
Tis true, sometimes it's a case of grin and bear it. It is always interesting to hear how folks deal with the problems that arise so thanks for the contribution. As for the MoT, let's hope the news is good. In fairness, once I have gotten all the faults sorted on the various Suzukis I've had, after that they have sailed through the MoT year after year. So get it sorted and then relax.Scutter wrote: I appreciate the sentiment - but I know I'm not going to get anywhere with this, and life is just too short to waste the effort. Just going to take it on the chin and move on.
Scutter wrote: Yes the ring around the ignition switch was made of plastic, which was connected to a small rectangular pastic unit that sat below the ring itself.
Those are the later ones and you can get fault codes from them using a decent scan tool, they should have a Tech 2 and if they used it they would have been able to tell the difference between the two faults.
The problem is that to most people this is all black magic, a decent mechanic should be able to follow the FSM though. If anyone else has this problem they should ask the dealer what the fault code was.
Hopefully the MOT won't be too painful for you.
Might be worth asking a few awkward questions. Personally if I felt suitablyripped off I would not let it lie and not using a code reader (well) is one of those cases.
