Piston broke!
20 Feb 2013 17:40 #63361
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Piston broke!
That little plate is held on with 2nd 10mm bolts. One is a bit hidden behind the clutch cable bracket.
Grey pick up Jimny
The following user(s) said Thank You: discotroll
- discotroll
- Visitor
20 Feb 2013 17:40 #63363
by discotroll
Replied by discotroll on topic Piston broke!
Yes to both - you don't seem suprised by this! :blink:
20 Feb 2013 17:41 #63364
by j999pre
Grey pick up Jimny
Just read it is no 3. Seems always to be the case. I think this was an issue on sj engines too
Grey pick up Jimny
20 Feb 2013 17:43 #63365
by j999pre
Grey pick up Jimny
Was there any light knocking noise before it died that was there a good few months? Top end. Quietened down when warm?
Grey pick up Jimny
- markyp2000
- Visitor
20 Feb 2013 17:45 #63366
by markyp2000
Replied by markyp2000 on topic Piston broke!
What engine is it single of twin cam i have a piston for a single cam engine
- discotroll
- Visitor
20 Feb 2013 17:55 #63368
by discotroll
I don't know about a light knocking noise - I thought it was a valve that had gone - it ran fine for about 10 miles making a lot of tapping from the top end then it cut to only 3 cylinders working (the spark plug got clobbered by the looks of things). I fully expected to see a broken valve or simlar when the head came off but it's all sat there looking perfect.
Markyp2000 - Yes, single cam - it is a size 2 piston (I understand that each cyliner is marked either size 1 or 2)...
Time to create page: 0.150 seconds
