Winch power cable
- Dan_w
05 Feb 2013 15:41 #60964
by Dan_w
Winch power cable was created by Dan_w
Guys does anyone know What gauge cable should I use to relocate the solenoid box higher in the engine bay on my winch? I plan to have it right next to the battery so can reuse the 2 existing cables but need a 3rd length. I have some 20mm squ AWG4 cable in the garage from an old sound instal. Would this be up to the job?
Cheers
Cheers
- TomDK
05 Feb 2013 15:43 #60965
by TomDK
Replied by TomDK on topic Winch power cable
Depends on how big a winch you have.
But in any case, 20 mm2 cable is too small.
You need 35mm2 at least, preferably 50 mm2 if you winch is a 9500 lb or more.
- Dan_w
05 Feb 2013 16:27 #60968
by Dan_w
Replied by Dan_w on topic Winch power cable
Thanks Tom, i had a feeling it would be too small, I will see what I can get hold of and decide where to position it all.
- TomDK
05 Feb 2013 16:32 #60969
by TomDK
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought som 60 mm2 cable from this shop on ebay
But they many different sizes
- mudman
05 Feb 2013 18:49 #60985
by mudman
Replied by mudman on topic Winch power cable
try curd bros on the north farm ind est tn23dg quite cheep auto sparks supler
- adamjimny
05 Feb 2013 20:33 #61014
by adamjimny
Replied by adamjimny on topic Winch power cable
i huse heavy duty jump leads and cut up and put on connectors etc.....works a treat and tested up to 800cca
Time to create page: 0.156 seconds
