Winch power cable
  • Sponnie
05 Feb 2013 20:37 #61018 by Sponnie
Replied by Sponnie on topic Re: Winch power cable
I used 35mm2 as reccomended by Arbil4x4, main uk agents for Warn. Its the same guage they use on their landrover installs for something like a Warn 9.5XP. If you were going great distance then you could consider 50mm2, to account for the voltage drop.
Sent from my GT-I9300 using Tapatalk 2
  • TomDK
05 Feb 2013 20:39 #61019 by TomDK
Replied by TomDK on topic Re: Winch power cable
For extreme use 50mm2 cable would be required for a Warn XP motor as it draws 480 amps a full load.
  • Sponnie
05 Feb 2013 22:51 #61051 by Sponnie
50mm2 is bigger than the standard Warn cables that were supplied with my winch from new. You are correct about the max draw. I have run a length of 50mm2 to the rear in case I relocate the batteries. 35mm2 is fine for short lengths.
If in doubt call Mr Bowyer. I can't see 35mm2 setting my Jimny on fire.
Sent from my Nexus 7
  • TomDK
05 Feb 2013 23:03 - 05 Feb 2013 23:19 #61054 by TomDK
My TDS 9.5c came with 50 mm2 cables. Warn 8274 comes standard with 50-60 mm2 cables.
I just wonder why the Warn 9.5XP winch only comes with 35mm2 cables. It is way underdimensioned for heavy use and long winch pulls. 35mm2 is only suited for up to around 370 amps.
But you're probably right. Okay for occasional Jimny use :)
Last edit: 05 Feb 2013 23:19 by TomDK.
  • Dan_w
06 Feb 2013 02:17 #61061 by Dan_w
Replied by Dan_w on topic Re: Winch power cable
Thanks guys, I was planning on mounting the control box under the bonnet but to do this it looks like it will cost me more than I expected :unsure: In the mean time I think I will mount it on top of the winch with the standard cable as it will be reasonable protected and move it once I have some spare funds to buy decent cable.
  • mudman
06 Feb 2013 10:15 #61080 by mudman
Replied by mudman on topic Winch power cable
www.halfords.com/webapp/wcs/stores/servl...yId=255204&langId=-1
or use jump leads as said by adamjimny have you tryed ebay?
Time to create page: 0.105 seconds
