KINGPIN BEARINGS! PLEASE READ!
- Skinhead
13 years 9 months ago #59582
by Skinhead
KINGPIN BEARINGS! PLEASE READ! was created by Skinhead
Now ive got your attention, can someone help me with my kingpin bearings? I havnt done anything like that before. It was advised on my MOT today as a swivel joint, the lad says my wheel has slight play top to bottom and also leaking grease from the swivel. I said "could it be the kingpin bearings" he said "no thats somewhere else, this is the swivel joint, the ball at end of axel" so i thought id ask on here. I would also like help fitting the new 1s or a very detailed video.
Thanks
Thanks
- TomDK
13 years 9 months ago #59585
by TomDK
Replied by TomDK on topic KINGPIN BEARINGS! PLEASE READ!
13 years 9 months ago #59590
Replied by mlines on topic KINGPIN BEARINGS! PLEASE READ!
You will be pleased to know you are correct and your MOT lad is wrong.
- Skinhead
13 years 9 months ago #59594
by Skinhead
Well that does make me feel good
any idea what seal i will need if theres grease leaking from the 'ball'? I will hopefully get someone to have a look just to make sure and ill be getting the bits from you.
Replied by Skinhead on topic KINGPIN BEARINGS! PLEASE READ!
mlines wrote: You will be pleased to know you are correct and your MOT lad is wrong.
13 years 9 months ago #59595
The seal that will be leaking is the small one inside the axle, you get one of those with the Kingpin Bearing kit.
The following user(s) said Thank You: Skinhead
- Skinhead
13 years 9 months ago #59600
by Skinhead
Thanks Martin.
Any takers around south yorkshire/north derbyshire???
Time to create page: 0.086 seconds
