KINGPIN BEARINGS! PLEASE READ!
  • mudman
  • Visitor
  • Visitor
25 Jan 2013 23:01 #59601 by mudman
Replied by mudman on topic KINGPIN BEARINGS! PLEASE READ!
the 1st set of king ping bearings and iner axle seal i done was on my jimny if you know what your doing with a spaner then just take bits off till you can get to what you need very easy job i would come and help but your a vit far away :laugh:
  • Skinhead
  • Visitor
  • Visitor
25 Jan 2013 23:16 #59610 by Skinhead
Replied by Skinhead on topic Re: KINGPIN BEARINGS! PLEASE READ!
Sponnie wrote: You will need a front wheel bearing removal tool that u can borrow. But i can't help pal, I've just had a hernia op.
Sent from my Nexus 7
How are you pal? I might just take mudmans advice and do it myself bit by bit, although i would like to see it done 1st. Have you got the tool? I cant spend 40+ on a tool i might not use again :blink:
  • vitara_mad
  • Visitor
  • Visitor
25 Jan 2013 23:37 #59613 by vitara_mad
Replied by vitara_mad on topic KINGPIN BEARINGS! PLEASE READ!
why do you need a wheel bearing tool to do the kinkpins ??????? ive never used 1 yet you don't need to undo wheel bearings
its a easy enough job to do just a bit messy
not a job i would be wanting to do outside at min
tom if you want help with them you got my number
  • Sponnie
  • Visitor
  • Visitor
25 Jan 2013 23:43 #59615 by Sponnie
Replied by Sponnie on topic Re: KINGPIN BEARINGS! PLEASE READ!
He said its leaking, so I presumed he was gonna change the seal in the axle? But your right he don't need them for just the king pin bearings.
  • vitara_mad
  • Visitor
  • Visitor
25 Jan 2013 23:45 #59617 by vitara_mad
don't need it to do the seal either the only time you need that tool is to change the wheel bearing realy
  • vitara_mad
  • Visitor
  • Visitor
25 Jan 2013 23:51 #59620 by vitara_mad
the small axle oil seal that you get with the kinkpin bearing kit ????
Time to create page: 0.170 seconds
