Steering wheel shake even though wheels balanced?
- Newell
13 years 9 months ago #59109
by Newell
Steering wheel shake even though wheels balanced? was created by Newell
Hello,
Just wondered if anyone can shed any light on my steering wheel shakes (pretty badly) even though I have had all the wheels balanced twice?
at around 40-55mph. Classic wheel out of balance symptoms, but they apparently are fine..
Its a 2005 Jimny vvt, on standard alloys and bridgestone dueler tyres.
Thanks, Kit
Thanks, Kit
- ne-crock
13 years 9 months ago #59137
by ne-crock
Replied by ne-crock on topic Steering wheel shake even though wheels balanced?
I'd look towards your kingpin bearings, they are the most common cause of the 'death wobble'
- iloveics
13 years 9 months ago #59150
by iloveics
Replied by iloveics on topic Steering wheel shake even though wheels balanced?
I wouldn't rule out unbalanced wheels, did you get them done at the same place twice?
When i went from standard wheels to modulars, the balancing machine at my work wouldnt balance them, so had to pay somewhere else to do it, however there is a slight wobble, that wasnt there before the modular wheels.
- fast forward
- Elite Member
- Thank you received: 7
13 years 9 months ago #59183
by fast forward
if you cant go round it go over it ! or vice versa ?
Replied by fast forward on topic Steering wheel shake even though wheels balanced?
sounds like the king pins as previously said ive got the same problem and it happens at the same speed as yours ,jack up the front of car and give the front wheels a wobble by hand and see if theres any play in them ! :woohoo:
- Newell
13 years 9 months ago #59223
by Newell
Replied by Newell on topic Steering wheel shake even though wheels balanced?
Ah the King Pins.. Ive heard that these can be pesky!
The Jimny has covered 45,000 Miles so is this likely?
I have just bought the car, anything else that I should check out that could be wrong with it too?
Thanks!
Here is a picture of it..
Thanks!
- gus2000
13 years 9 months ago #59278
by gus2000
Replied by gus2000 on topic Steering wheel shake even though wheels balanced?
Hello.
I attach a Suzuki Service Bulletin
Believe that the but important refers to the adjustment of the new bearings of the kingpin with spring balance.
Sincerely
Gustavo - LU2HC
Sincerely
Gustavo - LU2HC
