Steering wheel shake even though wheels balanced?
- MWells
- Visitor
24 Jan 2013 08:17 #59387
by MWells
Replied by MWells on topic Steering wheel shake even though wheels balanced?
They are alot cheaper from the shop on
here
and you know they will be correct as well and get good service.
- Newell
- Visitor
13 Feb 2013 23:16 #62484
by Newell
Replied by Newell on topic Steering wheel shake even though wheels balanced?
Today I jacked up the body and gave the wheels a shake, couldn't find any play in them..
Another symptom I have noticed is a knock in the steering wheel when going over gentle bumps at speed, for example when going over a rough patch on a motorway. Could this be linked to the problem? Worn suspension bushes?
Feels like its getting worse but its probably just my imagination, 45-55 is at its worst. Getting pretty annoying!!!
- adamjimny
- Visitor
13 Feb 2013 23:20 #62485
by adamjimny
Replied by adamjimny on topic Re: Steering wheel shake even though wheels balanced?
Have you checked both side to side play AND top to bottom play? Also backwards and forwards...
If no play could be steering rack/column
Sent from my GT-I9300 using Tapatalk 2
- adamjimny
- Visitor
14 Feb 2013 00:03 #62490
by adamjimny
It could be the radius arm bushes thinking about it so check those (usually the chassis end)
- darthloachie
- Visitor
14 Feb 2013 11:52 #62513
by darthloachie
Replied by darthloachie on topic Re: Steering wheel shake even though wheels balanced?
check the track rod ends as well as these can cause the wobble
Time to create page: 0.314 seconds
