Steering wheel shake even though wheels balanced?
  • MWells
  • Visitor
  • Visitor
23 Jan 2013 16:40 #59296 by MWells
It could also be worn panard rod bushes.
23 Jan 2013 17:10 #59299 by fast forward
yes is likely at that mileage as mine is similar mileage on suzuki 02 and has same problem are you losing grease onto your drive yet ! :(
if you cant go round it go over it ! or vice versa ?
  • Newell
  • Visitor
  • Visitor
23 Jan 2013 20:59 #59341 by Newell
Not losing any grease yet. Ok so.. If it is the Kingpins, would fitting a steering damper help?
So say its the kingpins (symptoms are all pointing towards this) Is replacing the bearings the done thing? Is this a sensible / possible thing to do at home? Would a standard garage cope with this, or would I need to visit a Suzuki garage?
Worth a look at the 'leading arm' bushes?
I have a small amount of mechanical experience from building old minis, but I have never even looked underneath a Jimny!
Thanks gus2000 for the service bulletin PDF!
23 Jan 2013 21:04 #59343 by dirtydogz
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
The following user(s) said Thank You: Newell
23 Jan 2013 22:40 #59371 by kirkynut
That service bulletin is interesting, Suzuki themselves think it can be only balancing, bushes or kingpin bearings. Well I have new ones of all of those with shimmed kingpins but my tyres have not been balanced for a while and I have steering wheel shake at 43mph - 48mph approx. Not full on death wobble but enough to make me want to resolve it.
So I have purchased some balancing beads to go in my tyres in order that they balance themselves all the time no matter what.
Once the snow has gone I'll pop them in and tell y'all the results. I'm hoping for a miracle cure. We shall have to see!
  • Newell
  • Visitor
  • Visitor
23 Jan 2013 23:26 - 23 Jan 2013 23:27 #59376 by Newell
No eBay APP ID and/or Cert ID defined in Kunena configurationSupposing I could afford this set, is it the correct one?
Last edit: 23 Jan 2013 23:27 by Newell.
Time to create page: 0.195 seconds
