Ready, steady, SLOW
- Cautiously reckless rick
03 Jan 2013 20:45 #57088
by Cautiously reckless rick
Ready, steady, SLOW was created by Cautiously reckless rick
I know the jimny is no dragster but since I've put 235 75 15s on it's on road performance is terrible. Has anyone tried any go-faster mods eg cat removal or air filter. I have also considered a corsa cdti turbo I have lying around which wouldn't need to much work to fit but not sure how ecu would take to it.
- Smoggy
03 Jan 2013 21:27 #57093
by Smoggy
Replied by Smoggy on topic Ready, steady, SLOW
Im running 285/75 16s and cant get 50mph from mine, it wont even hold 45 on a tiny incline and unless im on the flat I have to change to 4th. Thats even with a rocklobster fitted :blush:
But it's FANTASTIC off-road so I dont care :laugh:
- darthloachie
03 Jan 2013 21:39 #57097
by darthloachie
Replied by darthloachie on topic Ready, steady, SLOW
1.6 vitara engine will do the trick
- Dutchjimny
03 Jan 2013 21:57 #57100
by Dutchjimny
Replied by Dutchjimny on topic Ready, steady, SLOW
31x10.5 and no power loss at all
- Hastiekid
04 Jan 2013 08:40 #57133
by Hastiekid
What, not even with all that stuff on it? :ohmy: The box ratios must be good
By the way what is a cut and turn front axle?
Replied by Hastiekid on topic Ready, steady, SLOW
Dutchjimny wrote: 31x10.5 and no power loss at all
- Dutchjimny
04 Jan 2013 16:32 #57157
by Dutchjimny
Dont forget it are AT's and a lobsterbox 4.16 ratio, when the car was raised with the full ora 3"liftkit the arms did not correct the castor enough to align the kingpin's back in the "top-bottom" position so we cut the welds on the axle each side to rotate the complete axle another 3degree and weld it back on i hope you understand what i mean? Will shoot some pictures tomorrow if any is intrested?
Regards, stefan
Regards, stefan
