Difficulty engaging first gear.
  • Greensuzks
01 Jan 2013 10:26 #56763 by Greensuzks
Replied by Greensuzks on topic Difficulty engaging first gear.
I replaced my clutch disc and pressure but same problem with my first gear. Now, I have to leave with it.
  • BAZZOOK
22 Jan 2013 22:56 #59214 by BAZZOOK
Replied by BAZZOOK on topic Difficulty engaging first gear.
before selecting 1st or reverse put it into 2nd gear. This slows down the spinning gears and makes it easier to get 1 st.
11 Oct 2022 00:44 #245378 by chronicle
Hi All,
Bumping this thread.  I have a JB43 manual and have trouble engaging first gear at the start of the morning.
I normally put it on other gears first to make it go to first.
When the engine/transmission warms up, I can shift to it without problems.
Do you reckon changing to the gear oil would solve this?
PS: i know that Jimny's manual transmission itself is finicky at best.  I checked the shifter bushings and are all in order.
11 Oct 2022 03:24 #245379 by Lambert
Years ago I once used a gl4/5 combination oil in my manual and it made changes between gears difficult. Swapping to the preferred gl4 solved it. However I only had problems once it was up to temperature. Gear oil is cheap so as a first things first it makes sense to swap it.
11 Oct 2022 04:13 #245380 by chronicle
Thanks mate.  My issue is the complete opposite of yours.  Will look into changing the oil first.
11 Oct 2022 07:14 #245382 by lightning
l wouldn't normally engage first gear while a vehicle is moving.
My Defender has never liked first gear when it's not stationary.
Time to create page: 0.108 seconds
