Difficulty engaging first gear.
  • wanderinstar
25 Dec 2012 02:57 #56163 by wanderinstar
Difficulty engaging first gear. was created by wanderinstar
As i will be fitting a new clutch soon, I was wanting a bit of advise. I have difficulty engaging first gear/ If I slow right down and apply firm pressure to the gear lever it will then engage. When the garage takes the box out to do clutch he says I can take box away to try and sort 1st gear problem out. Would this just be a case of fitting a new syncro ring or would other parts be involved??
25 Dec 2012 09:40 #56164 by facade
They all do that Sir! B)
Some people report success with these new fangled fully synthetic gear oils developed especially to help Japanese gearboxes go into 1st.
I don't think that you will find anything wrong inside the gearbox.
If you want to throw money at it, new bearings, synchros and reshimming the gear clusters to spec might help.
  • wanderinstar
25 Dec 2012 11:02 #56167 by wanderinstar
Replied by wanderinstar on topic Difficulty engaging first gear.
No not all. I test drove one , while looking for one and first was perfect. As good as the other 4 gears. Whether it had had a new box fitted I dont knowHope you are not pulling my leg about synthetic gear oils. If not do you have any makes?
  • JerseyJimny
25 Dec 2012 11:08 #56168 by JerseyJimny
Replied by JerseyJimny on topic Difficulty engaging first gear.
Mine dosnt like 1st on the move as well... Anything speed about 10 mph its stubborn to go into 1st
I would only worry about it if you have difficulty getting into 1st while stationary
  • GuardianAngel
25 Dec 2012 12:38 #56169 by GuardianAngel
Replied by GuardianAngel on topic Re: Difficulty engaging first gear.
Mine does this sometimes even when stationary. A couple of waggles and dips of the clutch sorts it out. I wouldnt worry about it.
25 Dec 2012 15:30 #56173 by kirkynut
I'm on my second Jimny - should never have sold the first but it was in the early days of Jimny's being modified!
Anyway, both have disliked first gear unless stopped. So I doubt you'll find anything wrong or make a difference.
I've had a new clutch a few years ago with no difference. Once in a while it doesn't like first when stopped either but I have found most cars to do that every now and then from all makes. So again, nothing wrong, just one of those things.
You learn to not go to first until stopped, which I seem to remember being taught to do all those years ago, before bad habits began as I drove out the test centre with the new found ability to know everything and be a rally driver just like all 17 year old young men in that situation!
Time to create page: 0.208 seconds
