Castor correction.... Help/advise??
15 Nov 2012 18:44 #53344 by facade
You won't get the old bushes out and in the new arms in good condition.
What you need is a polybush kit, these go in with your fingers.
Stand car on level surface, handbrake on.
Work on one side at a time.
Undo the nuts on the 3 large bolts. (This is V difficult, as suzuki put the nuts on the inside. Undoing the bolts is even more so. There isn't enough room to use the Landrover trick of a 12foot scaffold pole over the end of the breaker bar) tap the bolts out, and the arm will drop down.
Replace the arm. You may need to chock the front wheel each side, and release the handbrake, then rock the car to get the last bolt to line up. Some folks use one of those ratchet straps to pull the axle.
The following user(s) said Thank You: ferreter
  • ferreter
15 Nov 2012 20:58 #53374 by ferreter
Replied by ferreter on topic Castor correction.... Help/advise??
facade wrote: You won't get the old bushes out and in the new arms in good condition.
Undo the nuts on the 3 large bolts. (This is V difficult, as suzuki put the nuts on the inside. Undoing the bolts is even more so) tap the bolts out, and the arm will drop down.
thank you, very helpful. thats a shame, i will try and see if i can get them out in resonable condition, of not look like another 80 odd quid on a polybush kit!
15 Nov 2012 21:19 #53382 by dirtydogz
Just save up the money and buy them later, using old bushes is false economy and if you can't get them out in one piece then your jimny won't be going anywhere. :pinch:
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • ferreter
15 Nov 2012 21:39 #53390 by ferreter
dirtydogz wrote: Just save up the money and buy them later, using old bushes is false economy and if you can't get them out in one piece then your jimny won't be going anywhere. :pinch:
ookay, will do that. dammit, im annoyed with myself now! should of asked this before i ordered! thank you everyone for you help
  • renard38
16 Nov 2012 08:18 #53422 by renard38
Replied by renard38 on topic Castor correction.... Help/advise??
sure, i used old bushes to put them in jimnybits radius arms:
[img
[img
  • Goat
16 Nov 2012 12:20 #53426 by Goat
Replied by Goat on topic Re: Castor correction.... Help/advise??
I've got those arms, got them with the bushes in though. They work great with my 3" lift, anti roll bar not needed.
Time to create page: 0.372 seconds
