Castor correction.... Help/advise??
  • ferreter
12 Nov 2012 15:57 #53024 by ferreter
Castor correction.... Help/advise?? was created by ferreter
Recently bought a jimny with a 3inch lift kit, with no castor correction, and the result is pretty terrifying!
This may not be helped by the fact there is no anti-roll bar fitted at the moment.
But can somebody tell me if it's worth spending 280 odd quid for the correction radius arms, or whether the correction bushes would be adaquate... Any advise would be appreciated as I'm new to jimnys
Cheers all, James
  • Paul4x4
12 Nov 2012 16:15 #53025 by Paul4x4
Replied by Paul4x4 on topic Castor correction.... Help/advise??
You need the castor correction arms if you want to get the steering geometry back to how it should be. Those bushes are only good up to 2" lift, and just help some if you have more lift than that, but they won't fix the castor completely.
  • ferreter
12 Nov 2012 16:41 #53026 by ferreter
Replied by ferreter on topic Castor correction.... Help/advise??
Thanks Paul, looks like I'll get the arms. Can I put the old bushes into the new arms? They look in good nick...
  • Paul4x4
12 Nov 2012 17:06 #53028 by Paul4x4
ferreter wrote: Can I put the old bushes into the new arms? They look in good nick...
Sure you can, if you manage to get them off in one piece! :)
  • markyp2000
12 Nov 2012 19:50 #53052 by markyp2000
Replied by markyp2000 on topic Castor correction.... Help/advise??
whos arms are you thinking off fitting
  • ferreter
15 Nov 2012 17:36 #53327 by ferreter
they arrived today :) cant see any fitting instructions though! anyone got intructions, or done it before?
grr
