Castor correction.... Help/advise??
- ferreter
15 Nov 2012 17:49 #53331
by ferreter
Replied by ferreter on topic Castor correction.... Help/advise??
jimny bits, they came today
- TomDK
15 Nov 2012 17:50 #53332
by TomDK
Replied by TomDK on topic Castor correction.... Help/advise??
Fitting instructions?
You remove the standard ones and replace with the new ones.
- ferreter
15 Nov 2012 17:54 #53333
by ferreter
im not that mechanically minded... although i get by. its just nice to check agaisnt a piece of paper, just in case. have you changed yours then?
- TomDK
15 Nov 2012 18:02 #53335
by TomDK
What would that help, checking against a piece of paper?
I have no need for new arms only new bushes, since my lift is only 2".
But if you need to get the old bushes into the new arms, you need a hydraulic press or maybe a good vise.
- ferreter
15 Nov 2012 18:08 #53337
by ferreter
to check i wasnt messing anything up. i understand it may seem ridiculously easy to you, but i just was after either some advise or sombody who had some instructions...TomDK wrote: What would that help, checking against a piece of paper?
15 Nov 2012 18:41 #53343
by facade
Replied by facade on topic Castor correction.... Help/advise??
You won't get the old bushes out and in the new arms in good condition.
What you need is a polybush kit, these go in with your fingers.
Stand car on level surface, handbrake on.
Work on one side at a time.
Undo the nuts on the 3 large bolts. (This is V difficult, as suzuki put the nuts on the inside. Undoing the bolts is even more so) tap the bolts out, and the arm will drop down.
Replace the arm. You may need to chock the front wheel each side, and release the handbrake, then rock the car to get the last bolt to line up. Some folks use one of those ratchet straps to pull the axle.
Time to create page: 0.169 seconds
