Speedo not working
- ripandcap
03 Nov 2012 15:57 #52080
by ripandcap
Speedo not working was created by ripandcap
Hi all i just bought, taxed, mot'd and insured my jimny and the speedo have stopped working. The rev needle is still working and everything else, i have checked the rev sensor connections, all the fuses i could find, checked all the wiring behind the clocks and changed the clocks and still not working. I also disconnected the batter for a few minutes and a couple of hours.
Any one have any suggestions?
- bluejimny
03 Nov 2012 16:14 #52083
by bluejimny
Replied by bluejimny on topic Speedo not working
check the speedo pickup on the transfer box, could be it
- ripandcap
03 Nov 2012 16:25 #52084
by ripandcap
Replied by ripandcap on topic Speedo not working
Thanks for reply, would the rev counter be working if it is the speedo pick up? Do i need to take the transfer box off to check that?
- markyp2000
03 Nov 2012 17:25 #52093
by markyp2000
Replied by markyp2000 on topic Speedo not working
the rev counter would still work if the speedo isnt its to different systems i think the speedo pick up is the bottom plug on the transfer box and there is no need to remove the box to change it also what year and engine do you have
- ripandcap
03 Nov 2012 19:23 #52126
by ripandcap
Hi Mark thank you for the info. I have an x reg 2000 jimny. Thats the plug and wires i checked which seem to be sitting in and the wires seem ok. Do it just pull out or will i need tools? How do i check to see if its working?
- markyp2000
03 Nov 2012 20:01 #52132
by markyp2000
tools i think and you may be able to test it with a good multi meter or if you have an oscilloscope even better
Time to create page: 0.158 seconds
