Speedo not working
  • ripandcap
03 Nov 2012 20:07 #52134 by ripandcap
Replied by ripandcap on topic Speedo not working
Thanks again Mark. Do you know where i will get one from or is it a main dealer part? Do the transfer box have to come off to remove the sensor?
  • markyp2000
03 Nov 2012 20:09 #52135 by markyp2000
Replied by markyp2000 on topic Speedo not working
on you said your self you have checked the wires so you have seen the speed sensor did you take the tbox out to check the wires?
try ebay
  • Rockwatt
03 Nov 2012 20:20 #52137 by Rockwatt
Replied by Rockwatt on topic Speedo not working
to remove the speed sensor it's just one small bolt and pull but don't forget to drain the oil in the transfer first or you will have oil everywhere :-)
  • ripandcap
03 Nov 2012 20:24 #52139 by ripandcap
no i didnt remove the box i just felt for looseness etc and checked the wires for splits/breaks. I changed the clutch a few months ago but the speedo has been working since then and it has only just stopped working now. i will slip underneath again tomorrow and have another look see if i can remove the sensor.
  • ripandcap
03 Nov 2012 20:26 #52140 by ripandcap
Thanks rockwatt that advise will come in handy and save me some oil to refill the transfer box.
  • ZookFastback
03 Nov 2012 20:55 #52164 by ZookFastback
Replied by ZookFastback on topic Speedo not working
My speedo stops working every now and then. I find that it is usually a loose connection under the fuses that are next to the battery so I just jiggle everything and then it normally comes good. If it doesn't immediately come good then it still fixes itself some days or weeks later.
In the meantime, for the G13BB engine, the following rev/kph figures are pretty accurate...
Non-lugging revs
5th gear 3000 revs 80 kph Most roads, arterials
5th gear 4000 revs 100 kph Freeway cruising
4th gear 2250 revs 50 kph Built-up areas
3rd gear 2500 revs 40kph School areas
Hope this helps, it does for me :)
Time to create page: 0.238 seconds
