engine and gearbox removal
- nate78
01 Nov 2012 23:03 #51912
by nate78
Replied by nate78 on topic engine and gearbox removal
any advice is more than welcome, as it stands, i am taking the 1300 out, putting the head on the 1600 block, using the jimny flywheel, new jimny clutch, vitara head gasket and bolts, vitara timing belt,jimny alternator,using the jimny starter, baleno injectors, i was thinking about drilling the gearbox to take the larger bolts instead of the adapter plate.
i plan on taking loads of pics for when i put it all back together, going to take the engine out then the box.
mate the head to the block then offer it to the gearbox and see what i need to drill,
once that is done put the box back then the engine, make a new engine mount.
sounds simple!!haha will change the fluids too and possible the box breather pipe
- Dave cc
01 Nov 2012 23:19 #51913
by Dave cc
Replied by Dave cc on topic engine and gearbox removal
Sounds like you are on the rite track engine mountings will need a bit of work i fabricated the O/S From scratch modified other side to suit.
Sump swap and pickup mod easy
Top gearbox bolts will line up just need to drill them out 12mm clearance lower 2 more tricky as they dont line up not sure how you can get around that think from SJ days fitting 8v vit engines some of the lads used to drill new holes in the block but cant be sure adaptor plates are cheap enough anyway.
Exsaust will clash as back of block wider but no biggy bit of cutting and snotting.
all really weird when you do it all seems to fit but only just !!!!!!!!!! you will see what i mean when you get into it.
- nate78
02 Nov 2012 00:08 #51914
by nate78
i didnt think that i needed to change the sump? is it necessary? if so why? maybe i should just buy an adapter plate,
- Dave cc
02 Nov 2012 07:56 #51928
by Dave cc
You dont have to change the sump just depends how much lift on the truck you have but the 1600 sump is a diffrent shape and can hit the axle if you dont have a fair bit of lift. :woohoo: if you fit the 1300 sump you will get more clearance to the axle but you will need to mod the oil pick up by either welding the 1300 strainer end to the 1600 tube or fitting a sleeve and o ring over the 1300 end where it sits into the block. Also when you fit the 1300 pick up you will need to drill and tap a hole M6 in one of the big end caps to secure the pipe to.
As for adaptor plate personal prefrence to use or not get 1 from Martin and it will be a nut and bolt job if not can see there being no other way than drilling holes into the block.
What 1600 16 valve bottom end are you using vitara or baleno ?
- nate78
02 Nov 2012 08:16 #51930
by nate78
im using vitara 8v bottom, ive got a small 1.5 inch suspension lift on my jimny so im hoping that will be ok, ive seen on the net people welding threaded bar to the gearbox inline with the holes on the block then using a normal nut to bolt the two together, i will have to have a look when i get there
- Dave cc
02 Nov 2012 10:18 #51939
by Dave cc
If you are using a 8v valve bottom end you will need to get 4 pockets milled in each piston to clear the valves a 8 valve piston has 2 pockets but they are in thye wrong place going to be a very short first run if you dont get it done :woohoo:
Time to create page: 0.214 seconds
