engine and gearbox removal
- nate78
12 Nov 2012 22:08 #53081
by nate78
Replied by nate78 on topic engine and gearbox removal
see, a little imagination and there is no limit! haha hopefully will make the mount in the week, looking to have it finished the weekend, thanks again for the help dave
- nate78
14 Nov 2012 21:04 #53271
by nate78
well i have dry fitted the engine, the drivers side mount lines up, the passenger mount is a little off, it look about 10mm to wide, i, thinking about cutting the base plate off and welding another moving it in a liitle towards the engine,
the sump of the 16v engine fits so thats good,
the starter doesnt quite fit, it is a little too fat, is it safe to grind a bit of the block?
i have taken photos and planning on doing a little write up once it is done
- Dave cc
14 Nov 2012 22:32 #53283
by Dave cc
Replied by Dave cc on topic engine and gearbox removal
Apparently you can grind a bit off the block so i have been told other way is skinny bosch starter but i think they are a rare find and they come from 8valve vits if i remember
why not do 1/2 and 1/2 bit of starter and bit off the block starter motor caseing is at least 5mm thick
- nate78
14 Nov 2012 23:07 #53289
by nate78
i did think that when i loooked at the starter, i will have a go tomorrow, it looks like it only need a few mm taken off for it to fit
- Dave cc
14 Nov 2012 23:35 #53293
by Dave cc
Old saying mate think twice cut once
as you say dont think there is much to come off
- nate78
15 Nov 2012 15:17 #53318
by nate78
yeah i will grind a little then test fit,
Time to create page: 0.335 seconds
